autometer speedo
Old Apr 14, 2008 | 10:49 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
autometer speedo
i had a autometer electronic speedo installed by a gm mechanic and it was working for 30 miles then stopped.when i start the car it still does what it is suppose to do but when i go down the road sometimes it works and sometimes it dont mostly dont.i called autometer and he said it probably isnt a ground and asked me how it was wired.i told him i didnt do it so he couldnt help me.if anyone has had or has the same problem i would appreciate any help.
Old Apr 14, 2008 | 03:59 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: autometer speedo
Can you not take it back to the guy that installed it for you? I'm not sure how your setup is since you have an 88 iroc and are using an electric speedo, but there are really only a few possible culprits.
1. VSS
2. guage itself
3 bad ground.
There really isn't a whole lot to wiring up one of these guages. just a signal wire, a ground, a headlight wire.
Old Apr 14, 2008 | 06:49 PM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
no i cant take it back to them they have a 30 day deal and my back went out so i have not been able to get under neath the car.i bought the sender they told me to buy so i guess i will have to get under the car and see whats up since its getting warmer.
Old Apr 21, 2008 | 07:44 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
I have been fighting this problem for a while but I finially have it fixed in my '83.
So you are running both the autometer electric speedo and the electric sending unit provided by autometer?
https://www.thirdgen.org/forums/elec...-problems.html
Old Apr 21, 2008 | 08:20 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
yes,but it sucks because my back is still screwed up.i dont no why the techs at autometer dont no the problem.im sure this isnt the first time they ever heard of this
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
90formulaVortec
Sep 8, 2015 12:42 AM
