Oil pressure gage acting up
Car: 86 ta
Engine: 333
Axle/Gears: stock
Basic info
86 ta
327 swap
high volume oil pump
can anyone help me out with this one? whenever i turnmy key to on or start my oil pressure gage shoots up to sixty. But if i turn the key to off it drops back down to sixty. i haven't started the engine yet, so technacily there should be no oil pressure. so why is my gage shooting up. i have a new sending unit. I thought maybe my grounds could by messed up. The whole wiring harness is a mess
86 ta
327 swap
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Oil pressure gage acting up
Check the connectors, they might have some extra resistence on them.
Or might be even disconnected.
If you disconnect the oil pressure sender and ground the wire on the block, the gauge should show 0psi.
Hope this helps.
Lou
Hope this helps.
Lou
