Which wire on pickup coil goes to P or N on module?
Old Apr 17, 2008 | 01:36 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
HELP! Which color wire on pickup coil goes to P or N on module?
I removed the ignition module and confirmed it was bad, now I have a new one and need to install it but I don't remember which way the yellow and green wires were attached to the old one
Yellow and green wire from pickup coil, P and N terminals on module. Which goes to which???
Does someone have a distributer lying around w/ the cap on they can tell me? Its not in the service manual!
Thanks!
Old Apr 18, 2008 | 08:39 AM
Car: 1992 Z/28
Re: HELP! Which color wire on pickup coil goes to P or N on module?
TTT
Old Apr 19, 2008 | 01:42 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
On my 88 IROC 305 the green wire is on the inside near shaft center or P, yellow (mine looks white) is outside near lip or N. I had the same problem and in the end it seems that its not that critical as either way you will get a pulse ( pos verse neg pulse would equate to a minor time variation). The only reference I found was in a parts photo that showed a darker wire on P and a lighter wire on N. A scope would clarify the pulse polarity... if I had one.
Old Apr 19, 2008 | 07:45 AM
Car: 1992 Z/28
Re: Which color wire on pickup coil goes to P or N on module?
That should work, thanks!
I was thinking I would need to drive to the parts store and hope they had a reman distributor and that they came with modules to look at
apo_bailon15
Mar 28, 2016 05:20 AM
stalkier
Dec 6, 2015 11:25 PM
Winchester1094
Aug 18, 2015 10:23 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
