A/C trouble???
Old Apr 24, 2008 | 09:57 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
A/C trouble???
Ok I have a 1989 GTA with 24,XXX miles and I'm wondering why is the A/C isnt working. Was there something wrong with the A/C systems in our cars years.
Hope you guys can help me thanks.
I dont plan on driving it just one of the routine check ups and noticed it forever but now just asking why?
Old Apr 24, 2008 | 10:14 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: A/C trouble???
When was the last time the ac was used? In many cases where a car is not operated very often, the seals in the ac system can dry out providing a convenient escape for the refrigerant. The best way to fix it would be to reseal the system and recharge. hope this helps answer your question.
Old Apr 24, 2008 | 11:40 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: A/C trouble???
I have the same car as your's. Similar mileage too.
You can lose a bit of refrigerant during the cold months of the year. Over time it can leak out around the seals yet still be fine the rest of the year. This is why in a 2.25 lb system, you might have 1.5 lbs still in there. If it was an actual leak, then you wouldn't have any refrigerant left in there.
Is it working at all? Is the compressor turning on? Is it cycling on/off, on/off way too often?
What kind of duct temperatures are you getting? (I use a kitchen probe thermometer)
Old Apr 25, 2008 | 04:24 PM
Engine: 350/350/LS1
Re: A/C trouble???
Yes it goes to the cycle and the air comes out but its not cold
Old Apr 27, 2008 | 08:17 PM
Car: 1989 GTA
Re: A/C trouble???
Yeah, I'd say you're a tad low on R-12. The compressor won't run long enough to get the system cold. If you had pressure gauges on there, you'd see the low side dropping to about 25 psi and then going back to 45 psi in rapid fashion.
Probably need about a half a can of R-12 in there. Maybe 1 can. Hard to say without actually measuring the charge.
With your car being low mileage, it's probably been a summer car only since day 1. Same as me (I have about 35,000 miles on mine). So I'd say your air conditioning system itself is probably in like new condition. Nothing worn out. You probably just need a top up.
jrdturbo
Mar 31, 2016 02:58 PM
mrbird
Oct 20, 2015 03:43 AM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Lmancha96
Sep 25, 2015 08:11 PM
