Need to identify one wire on my 89 T/A harness
Old Apr 28, 2008 | 08:46 AM
Ob_one's Avatar
Car: 89 T/A Blue/Gray T-Top
Engine: 5.7
Axle/Gears: 327
Transplanted a 90 IROC 5.7 into a 89 T/A 5.7
There is a single green wire connector that comes out of the engine harness near the distributor next to the connector that goes to the back/underside of the Tune port. Don't know where it goes to.
Also the 4 wire connector to the distributor module is coming up short. Is there a difference between the 90 Iroc 5.7 distributor module mounting and an 89 T/a 5.7 distributor mounting module?
The module on the 90 is facing the 11 o'clock position. if it were facing the 1 or 2 o'clock position it would plug right up.
Any help would be greatly appreciated Thanks in advance.
Old Apr 28, 2008 | 10:26 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Need to identify one wire on my 89 T/A harness
That wire went to the EGR for temp...not needed on a '90.
You can reposition the dist so the wires will reach, lift the dist and move it a couple of teeth.
Old Apr 28, 2008 | 10:51 AM
Ob_one's Avatar
Engine: 5.7
Axle/Gears: 327
Do i need to get a an 89 T/A EGR valve so i can plug that wire into it or is that not important. I dont want to have any check engine lights on. I need to have this car pass emission here in GA
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
stalkier
Aug 21, 2015 01:54 AM
