Steering Column HELP PLEASE
Old Apr 30, 2008 | 09:05 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
ok, so i got in my 92 RS today, and it decided that the steering column was going to be all gay. At first if i adjusted the tilt wheel lower, it would stick in lock position when turning right. if i put it up as far as it will go there is no problem. then when i went to go start the car again it wouldnt do it, so i dropped the steering column and puled the bar from the ignition switch up and turned the key, it cranked and started. I can probably figure out the ignition switch thing, But i hacve no idea how to get the wheel to stop sticking. I really need it to not stick, my g/f drives this car and when she does the tilt wheel is down, she WILL crash and panic if the wheel locks up on her. Help. please.
Old May 2, 2008 | 12:40 AM
92WhiteZ28's Avatar
Re: Steering Column HELP PLEASE
nvm, i took it all apart and fixed it today.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
