Hatch motor HELP!!!!
Old Apr 29, 2008 | 03:55 AM
karl's-92'-z28's Avatar
Car: Too many cars
Ok heres the problem. When I push the rear hatch button the hatch goes all the way up then back down & locks. So if I wanna open it I gotta hit the switch then run behind & pull it up when it releases before it goes back down.
I have a new motor, new/used hatch struts & switch, new fuse. The old motor was working fine until one day it went down & stayed on.
The motor is adjusted all the way up, Im just out of ideas what could be the problem.I dont think its any of the relays, when I use the key I can pull the hatch open & it comes up & stays up till I close it.
Old Apr 29, 2008 | 10:18 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
Re: Hatch motor HELP!!!!
I think this is a common problem. Mine did that for the longest time until I replaced my motor when the shaft finally broke.
I would adjust the motor downward, and if you can't get it that way try the alignment of the hatch catch to the latch in the motor. If it isn't aligned it could be caudsing that issue.
Old Apr 29, 2008 | 11:57 PM
sbingner's Avatar
That would be because the trunk is lifting, but then when the pulldown reaches the top of its cycle, it presses on the trunk so much that it snaps back which makes it pull it back down. You could also see about replacing your shocks for your trunk, if they lift up more on the trunk it could help... if you wanted to really jerry rig it, you could put some sort of spring under your trunk to make it go up higher.
Old Apr 30, 2008 | 12:49 AM
Car: Too many cars
I have new struts on, the old ones I had on their couldn't hold up the hatch. Yeah I was thinking about that spring idea, only thing is were to put it & how strong of a spring.
Old Apr 30, 2008 | 04:35 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
sounds like the striker switch needs replaced. it stops the motor when going up/down positon.
striker swtich from TDS http://www.top-downsolutions.com/pro...products_id=62
Old May 1, 2008 | 05:36 AM
Car: Too many cars
So the new hatch motor doesn't come with it Im guessing?
Old May 1, 2008 | 01:44 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
nope its seperate from the motor
Old May 2, 2008 | 01:12 AM
Car: Too many cars
Dam gotta spend more $$$$..hahaha thanks guys I guess I'll have to order 1 & I will let you all know if the problem is cured.
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
