87-92 Headlight motor removal!!
Old May 3, 2008 | 11:22 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Hey all.
Tonight I wanted to try and fix my driver side headlight motor. It spinns freely, need help to go up and down. Been like this for 6 momnths.
I assume it is just the bushings. I wanted to take it out, and try sticking some slices of hot-glue stick in there as new bushings. Reading the haynes book, I tried to remove the motor to bring it to the basement workbench to make new bushings for it.
I got the bezel off no problem. Got both motors unplugged for now to keep the lights up. The next step was to "use a screwdriver" to pop that arm off the headlight housing, the one that goes from the motor to actually flip up the door. It has some sort of "ball joints" almost like a little mini tie-rod end. I pushed as hard as I could, prying off a piece of solid sheetmetal. I bent the screwdriver.
So... my question is. How am I supposed to pop this goddamn arm off the headlight. After that, I think the bottom side can unbolt from the motor itself. But I gotta get the top end disconnected first.
Another thing to keep in mind, is that when I get the motor out, I need to be able to keep the door and sealed beam on the car. I will use duct tape for a few days to keep the thing from closing. But I need to have 2 headlights so I dont get pulled over and hassled by the 5-0 they dont like me in this town.
Thanks!
Old May 4, 2008 | 12:01 AM
snapcase303's Avatar
Car: 91 firebird formula
Re: 87-92 Headlight motor removal!!
im not sure which style you have but ive got a 91 formula and it has the headlight where u can just replace the nylon dials in the motor and that fixes them if you look on ebay for the repair kit it only costs 10$
Old May 4, 2008 | 12:28 AM
Engine: LO3
I know, that is what I am trying to do. Lon at TDS also makes a kit that repairs the motor, but I wanted to try the glue stick trick first.
If you have a 91, we have the same setup basically. How did you get the motor disconnected from the headlight door?
Old May 4, 2008 | 10:16 AM
Engine: LO3
so nobody knows how to disconnect that arm??
Old May 6, 2008 | 11:06 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i got mine off by doing what you did. without bending the screwdriver. try one of thoughs door panel removers that is like a prybar it worked for me the second time i did this and it wont slip
Old May 6, 2008 | 11:14 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
i bought the rebuild kit and followed the directions. seriously, 25 bucks is not that much to spend to fix your headlights. dont be cheap.
Old May 8, 2008 | 06:05 PM
Engine: LO3
Well guys, I got it kinda fixed.
I managed to get the motor off, without disconnecting the arm. I decided to give it a shot when I had the sealed beam headlight out for replacement. Made it much easier to get to the bolts.
I ended up removing the whole headlight assembly by unbolting it from the radietor support. Wasnt too hard.
I ended up repairing the motor using some sliced hot-glue stick as bushings. It works OK now, but kinda lags a little on the way up.
I broke both bolts on on the motor taking it apart, so I had to drill the holes out and use some spare hardware. Its real ghetto. Also, the gasket broke into pieces, so I used globs of RTV to seal the motor together.
And I lost that little ball on the end of the shaft. Not sure what it did, but seems to work wothout.
The reason I didnt buy the kit from TDS, is because 1 I dont want to borrow my moms credit card. and 2, I had a feeling I was gonna **** the motor taking it apart anyhow.
When it goes again, I will get the Cardone reman unit, and then use that for a while.
Old May 9, 2008 | 01:29 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You'll need that lil ball. It supports the end of the motor shaft. There is a threaded shaft with the mating cup on the ooposite end sticking out the bottom of the actuator assy secured with a sheet metal locknut. Without the ball bearing the worm-drive shaft of the motor will not be supported. It will climb the gear at the end of the up or down-cycle and jam. You'll find this out when you need to turn the **** on top of the motor to free it up so the motor can spin freely. Yes I sell used ball bearings on my site.
Lon
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
