Ignition Problem
Old May 9, 2008 | 10:46 AM
WhtIroc's Avatar
Ignition Problem
So I have this problem where I don't get a spark from the distributor..
So there's a new ingnition module, pickup coil, distributor cap, and ignition coil. But still no spark.
Anybody know why and could help me?
Old May 9, 2008 | 03:17 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: Ignition Problem
have you even checked power to the ignition? if you have no power, all those parts aren't gonna help.
Old May 9, 2008 | 03:28 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
double check the connection where the module plugs into the pickup coil. i recently had a no spark issue and one of the wires from the pickup coil somehow got pushed back inside the connector.. so even though it looked like it was plugged in.. it wasn't.
Old May 10, 2008 | 04:49 PM
WhtIroc's Avatar
aaaahhh... One of the connectors was backwards.. After some heavy cranking and a little bit of backfiring it started up.
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
