bypass memory recall
Old May 10, 2008 | 04:53 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I was wondering about wiring up my digital temp gauge for my car. It has a memory recall and a little trigger button to reset it. I can leave that out correct if i dont want to use it?
It is a cyberdyne temp gauge if that helps out all. ?Its electrical and it has a seperate signal wire
Old May 10, 2008 | 10:28 PM
tripingeorge3's Avatar
Re: bypass memory recall
the extra wire should just be a power source. like for it to light up and do the recall. the other should be a ground and the sensor wire for the gauge to read off the sensor. u need the light so i'd just hook it up the way its supposed to be
Old May 17, 2008 | 08:18 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
nono I have the power wired up the ground wired up the light wired up and signal also, but there is another that is for like memory recall. i think im fine, but idk.
$750 L98
Feb 1, 2025 02:25 PM
Vintageracer
Sep 24, 2017 12:34 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Formula8r89
Sep 22, 2015 04:24 PM
