How to install a hatch release switch ?
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Hello
I have an 89 rs and i wish to install the release switch in my console and I was asking what parts i need?? or only a switch and some wires to the rear of the car??
and were I have to connect so it works perfectly and I can open the hatch from inside the car!!
thanks and if you have what I need let me know!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: How to install a hatch release switch ?
You should already have the connector from the dash harness to the center console in your car. You will need a relay and harness from an 88 & up car as the 82-87 ( or so ) relay and harness has a different plug on it. To complete the set-up you will need a console button, a 86-90 PPD hatch motor "pop" soleniod ( the 82-85 hatch pop soleniod is different ) and a long heavy gauge wire to connect the relay to the soleniod. ( if the wire was cut from the relay/harness )
Hope this helps !
Hope this helps !
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
thanks for the reply but idont have any connection because i just opened the console and there is nothing!! may be because even the windows are manual and there is no connection but the hatch motor is there because it is an 89rs and it works perfectly!!
i taught i can bridge 2 wires from the back to the console and is done!!
i am sorry but a circuit diagram will be morehelpful if you have any
thanks again
thanks again
Car: 1990 Camaro RS
Engine: L03 305 TBI
The hatch motor and solenoid are two different parts. The motor pulls the hatch down. The solenoid pops the lock, like when you unlock it with the key.
You should have those wires in your center console though. Mine were on the left side, right below where the box sits (90 RS, manual windows, no factory hatch release). They may be tucked under the edge of the carpet.
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
i will check again tomorrow!!! even urs is without power windows?? and no hatch release?
if there is the connector will do my best to buy the selonoid and switch!!
thanks for the help!!
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
