Headlights-only one raises, already used the repair kit
Old May 12, 2008 | 04:34 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
I'm looking for advice on how to figure out what is wrong with my passenger side headlight.
About a year ago the headlight was showing signs of the "spinning top disease" where the motor would run but the light wouldn't go up. So I used Lon's kit to replace the plastic bushings which had turned to dust. In the course of the repair I removed the entire headlight assembly from the car to bring it inside. The light worked perfectly for about two weeks.
Then the light stopped going up. When I flip the switch in the car, the left one goes on the right light turns on but won't raise. If I manually go and turn the motor about one turn, and then go and retry the switch to raise the light, it does go up on its own. It will usually work well for the rest of the day, and be "stuck" again tomorrow.
How should I go about diagnosing the problem? Do I need a new/rebuilt motor, headlight control module, or did I somehow cause something to bind when I reinstalled it?
Thanks for your help guys.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
mrdevontay
Sep 2, 2015 08:04 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
