AIR select valve on my 84
Old May 15, 2008 | 04:19 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
i am trying to find a place to wire my heated 02. i want the element to shut off upon entering closed loop. which wire is hot on theair select valve? pink w/black stripe or solid brown? i am hoping it is the pink one b/c there is 2 brown wires in that harness. thanks for ur help.
jay.
Old May 16, 2008 | 04:23 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Re: AIR select valve on my 84
ttt
Old May 16, 2008 | 08:39 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The pink/black wire is hot with ignition on, and the ECM pulls the brown wire to ground to activate the AIR select solenoid. It's the same brown wire that goes to terminal C in the ALDL connector.
With a 4-wire O2 sensor it might be possible to wire it in directly, but I don't know how much current it draws and if the solenoid is activated in closed or in open loop.
So your best bet is to put a relay in place of the AIR solenoid.
Old May 16, 2008 | 09:48 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
thanks dude. thats what i needed. i am almost possitive that it is operated in open loop then goes to ground upon entering closed loop.
thats the reason i wanted to use the air select valve. it comes on when the car is running in warm up and shuts off when the o2 reaches its temp.
iam goin to buy a Chiltons today after work. i've been putting it off for no real reason. so i'll confirm it is the correct wire.
thanks again.
jay.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
db057
Aug 22, 2015 08:17 PM
jackhammer
Aug 15, 2015 10:04 PM
