Hatch Pull Down Motor
Old May 20, 2008 | 08:20 PM
skittles's Avatar
I have a 91 Camaro RS V8 305ci. My hatch pull down motor completely stopped working after 1 year of erratic behavior(like running up and down non-stop when the car is running). So I examined the hatch motor area and found the motor housing cracked and the guides were destroyed. I saw good comments about topdownsolutions, so I bought the deluxe kit: New Motor and housing, new guides,and a new gear nut. Installation was easy, except the guides. I had to grind down significantly to get them to fit. I hook-up all the wires, turned on the ignition, closed the trunk and..........nothing. No sound of the motor. No movement. So I test the wires going into the hatch motor....I found power going all the way to the reversing switch that sits directly on top of the motor. I thought it might be the solenoid so I bought a new one...and of course, no change. The "LID" fuse was fine. The hatch release works fine. I am really at a loss here, and I do not know how to proceed. Any help or advise is greatly appreciated.
Old May 20, 2008 | 10:16 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: Hatch Pull Down Motor
Hows your switch?
Old May 20, 2008 | 11:17 PM
skittles's Avatar
Witch switch? The striker switch, or the reversing switch?
Old May 21, 2008 | 08:54 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Lon at Tops Down, who is also a member and sponsor on this site, has all the parts you would possibly need to fix your hatch pull-down unit. He is also good at answering questions.
Old May 21, 2008 | 10:27 PM
Car: Too many cars
The hatch release switch on the center console.
Old May 21, 2008 | 11:49 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
He just said it works fine.
From what you're saying it sounds like your reversal switch might be bad. I'd wait for Lon to reply though. He could probably have it all troubleshot and everything in a post or two.
That, or the guides are causing too much pressure for the motor to even attempt movement. I remember that Lon's instructions included three different ways to install the guides so they'd be tighter or looser. Didja read that?
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
