84 trans am computer?
Old May 26, 2008 | 09:16 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
I am not positive if this is the right forum, so i apologize if it isnt.
I have a 1984 trans am which i recognize has a computer controlled carb just like my old monte ss.. but do I have an actual computer controlling it or is it a closed loop between the carb and distributor? I am removing all emissions components and want to eliminate every wire I dont need.. and this thing has a ton of wires.... So do I actually have a computer somewhere? And any info on what wires I can axe since i am going with an ancient motor combo (68 model 327), ditching the stock carb/hei and no emissions BS.
Thanks!
Old May 27, 2008 | 09:20 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: 84 trans am computer?
Yes, if there is a TPS & an MCS connector on the carb, and an extra connector to a distributor w/o a vacuum bell then you have a computer somewhere. It's usually in the passenger foot area. Be aware that the converter lockup will be disabled when removing the computer. Kits can be had to replace that function. Wiring can usually be removed as a complete assembly, just follow it when you find the ECM.
Old May 30, 2008 | 08:28 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Your CLCC quadrajet has an ECM that is located behind the glovebox area of the dash. Pull the kick panel in the passenger footbox and the ECM is held in place by two screws. It'll drop down into the footbox. The wiring goes through the passenger-side fender and into the engine compartment. You can disconnect the harness without cutting it by pulling the big clip on the bulkhead connector, then feeding it through into the fender.
Too bad about that Qjet: I ran mine up until the time when I converted to fuel injection: During it's last season in operation, it (with the 305 H.O.) gave me 21 MPG on the highway and the car was running 14.00 at 101 MPH. THe dyno read 262 RWHP when we tested it. I liked that carbuerator combination. Let's see how your 327's performance stacks up when you are done!
Old May 30, 2008 | 01:15 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually some EXPORTED cars did not recieve an ECM. If you have one you remove the lower trim panel and there are two 7mm screws that hold it up (usually the thing furthest to the right. Usually you can spot it because there is a bunch of wires coming out of the ECM.
John
Old Aug 29, 2010 | 07:49 PM
dodge01man's Avatar
do you know where i can get one of those lock up kits for the convertor i would like to take out the computer but i need that locked up. thanks
Old Aug 11, 2011 | 04:26 PM
1slobird's Avatar
Car: 85 trans am
Engine: mildly built L48 350
Axle/Gears: 7.625 with 3.23s and g80 gov loc :(
if you dont mind the check engine light you can just tuck the wires back thats what i did to my 85 trans am when i swapped to a '72 l48 350
eightsixseven
Dec 16, 2024 01:50 PM
stalkier
Dec 6, 2015 11:25 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
jharrison5
Aug 19, 2015 05:53 PM
