can I do this
Old May 30, 2008 | 02:50 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
can I do this
I would like to tap into my 12 volt switched lead feeding my coil to power my three wire O2 sensor. Would this be OK?
thx
Jeff
Old May 30, 2008 | 03:22 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: can I do this
What's the current rating on the heating element on the O2 sensor? You don't want to exceed the whole IGN circuit amperage.
I'm sure 1 amp would be ok, 10 amps would be a no-no.
Lou
Old May 30, 2008 | 04:10 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: can I do this
I'd use one of the pink/black wires as a power source. I'm pretty sure the O2 heater draws well under 1 Amp.
Old May 30, 2008 | 06:22 PM
jjlabinski's Avatar
Engine: shinny 350
Re: can I do this
thank you
