Power windows
Old May 30, 2008 | 11:12 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Power windows
Are the windows supposed to be able to work when the key is in acc mode? It doesn't work in that mode, only when the ignition is on, also when it is in acc it keeps beeping.
Old May 31, 2008 | 10:05 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Power windows
Power windows work only with the ignition on.
Hope this helps.
Lou
Old Jun 2, 2008 | 11:23 PM
smallblockking's Avatar
Re: Power windows
is there anyway to bypass the keyed power to roll up or down the windows?
please pm me with info
thanks
dan
Old Jun 3, 2008 | 10:00 AM
BigBadLou's Avatar
Engine: TPI
Re: Power windows
Yes.
Do you want to roll them up by hand or with your alarm remote?
We are about to install a remote window roll-down on a car here. It's very useful, especially in Texas where the mid-May temperatures climb into upper 90's with no problem.
If you want to roll them up by hand, you can install an extra switch or if you want to tie it to your alarm, you'd need a relay. Anyway, you'd have to tap into, let's say, the PWR ACC circuit. It's strong enough to power both windows.
Lou
Old Jun 3, 2008 | 03:43 PM
Car: 86 Z28
Re: Power windows
I just thought that my wiring might be effed up, because on my dads 90 silverado they work in acc.
Old Jun 3, 2008 | 04:51 PM
BigBadLou's Avatar
Engine: TPI
Re: Power windows
I know exactly what you mean. I myself miss that feature (yeah, I used to own a Ford ).
I might look into making our windows work in the ACC position. I am swamped right now but it's a definite future project, I can say.
Lou
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
