Weird of loss of power problem...
Old Jun 5, 2008 | 03:51 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Yesterday, while driving I took a look at my guages and my battery was below 13V while at highway speed. A minute later the volts were rapidly decreasing all the way to below 8V. None of my guages were working and the infl rest warning was on in the dash. My radio was also turning off and on. The voltage had gotten low before but never like that. I always thought it was because of my underdrive pulleys because I heard they cause charging problems. After about ten minutes of driving the voltage went back up to just above 13V.
I removed my radio just to make sure that wasn't the problem.
However, today the samething happened while on the way to work. When I got in the parking lot the car died.
I have a brand new 140amp alternator less than two months old.
By the way engine is an LT1. I don't see any loose grounds and messed up wires.
Could the underdrive pulleys be causing this problem. Any suggestions would help. I will have the alternator tested today.
Thanks,
Jay
Old Jun 6, 2008 | 01:01 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Weird of loss of power problem...
get the altenator load tested.. most likely failed.. had a new one fail on me 3 days after installing .. needless to say napa ate an altenator and i changed it in the parts store parking lot:P
Old Jun 6, 2008 | 10:22 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Had the alternator tested. Result was low charging volts. The wire coming of the back of the alternator was alittle burned. I changed the wire and everything seems to be working properly. I will monitor it for a while though.
Thanks,
Jay
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
novaderrik
Aug 10, 2015 12:44 PM
