Distributor
Old Jun 11, 2008 | 03:03 PM
Camaro_dude92's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: 3.1 V6
Transmission: Stock Automatic
Axle/Gears: Stock Chevy Axle and Gears
Distributor
Hi, I have a 1992 Camaro RS with a 3.1 V-6 and have a question. I was wondering how to properly install the distributor in the engine block. I forget the way it's positioned in the engine and my Hayne's manual doesn't help much. Any feedback would be much appriciated.
Old Jun 11, 2008 | 04:03 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Distributor
The idea is to get it so the rotor is pointing at the #1 spark plug terminal when the engine is at top dead center. If you didn't mark where it was pointing when the dizzy was removed, you'll probably have to turn the engine by hand until it's at TDC. Pull the #1 spark plug, and stick a piece of crumpled up paper towel in the spark plug hole. Then, using a breaker bar, turn the engine over by hand, until the paper pops out, and the timing mark on the balancer is at zero on the pointer. Now, reinstall the distributor. You may need a long slotted screwdriver to turn the oil pump too, so it lines up with the distributor.
The paper towel trick is to make sure that cylinder #1 is on the compression stroke, not the exhaust stroke. If you have a helper, you can also just have them put their finger over the spark plug hole, and check for air coming out.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
