MSD Question??
Old Jun 12, 2008 | 05:52 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
MSD Question??
Ok, I'm going to run a 6AL witha blaster ss coil, my question is, how do i get the factory tach to work since I'm not using the replacement type coil? I'm thinking it will just take a tach adapter, but how and which one?
Old Jun 15, 2008 | 11:08 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Re: MSD Question??
Anybody got any idea???
I'm going to be doing the motor swap in a few weeks and dont want to put any aftermarket gauges in the car except for a nice pillar mounted oil and water gauge ( It's a very expensive motor)
I was going to just use the ALL stock gauges but my buddies talked me into using water/oil gauges cause you really dont want to let those go electric (unless they are the $200 autometer ones WOW!!!)
Old Jun 17, 2008 | 01:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: MSD Question??
Sorry I cant help, I'm using a stock coil. I bought MSD's quick-connect harness and plugged that into my MSD 6A, and everything works just fine, even the tach.
Old Jun 22, 2008 | 02:25 PM
georgealtemus's Avatar
Car: 1987 gta trans am
Engine: 5.7l 350 supercharged and more
Transmission: 700r4 w/shift kit
Axle/Gears: moser 12 bolt w/373 aubern posi
Re: MSD Question??
Just like kevin91z said get the msd quick connect and youre tack will be fine.
Old Jun 22, 2008 | 08:45 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Re: MSD Question??
I'm not using a STOCK coil, I have a blaster SS coil. The stock coil is no good for a 600hp motor.
Old Jun 24, 2008 | 06:53 PM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
Re: MSD Question??
im using a 6al box and it has a tach output that you can hook your tach up to
Old Jun 24, 2008 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: MSD Question??
Doesn't matter what coil you use, connect the tach to the tach terminal on the box.
There's nothing wrong with electric gauges either, BTW.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
