Knock Sensor
Old Jun 13, 2008 | 07:05 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Knock Sensor
Is there a way to tell if I have the correct Knock sensor? Is it stamped with a part number or something? Doers it look the same as the 305 KS? I have a 91 RS that had a 350 out of a truck (presumably an L05) put in it. I want to verify that they put the correct knock sensor in it. I'd rather not mess with changing it if I don't need to.
Old Jun 13, 2008 | 11:36 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Knock Sensor
I think that you are correct in questioning this point. When a 305 is replaced with a 350, I believe one of the things that need to be done is install a 350 knock sensor. The 305 and 350 knock sensors are different.
Do a search, this is asked many times.
Old Jun 15, 2008 | 01:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Knock Sensor
The 305 and 350 knock sensors do need to be changed to the proper motor size when the engine is swapped. However, they physically look the same and I didn't see any real labeling on them to be able to tell the difference.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
