timer for interior lights??????
Old Jun 25, 2008 | 07:58 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i was reading my owners manual and it said after you shut your door your lights should dim out after 30 seconds. it also says after you shut the car off the lights should come on for 15 seconds??? mine only come on when i open my door. and as soon as i shut my door they go right off? is there a timer that could be bad or bypassed if so where is that located??
Old Jun 25, 2008 | 11:02 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: timer for interior lights??????
Are you sure you're talking about a thirdgen? Our cars have no timers for headlights or dome lights.
Old Jun 26, 2008 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I "seem" to recall something about opera lighting on Berlys. But the memory is vague and I'm old. I surrendered to curiosity:
https://www.thirdgen.org/forums/inte...=lighting+fade
JamesC
Old Jul 4, 2008 | 08:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Berlinetta used a computer ( really a relay center ) to control all the cars internal and external lighting functions. It allowed the high beams to be used without the headlights as a "Flash to Pass" feature and automatically turned off the headlights when the key was turned off.
Another cool option was that the interior "courtesy" lights were on a timer. Open the door and the lights go on - turn the key ON and the lights go off. Turn the key OFF and the lights come on. When you open the door get out and close it the courtesy lights would be set on a timer and shut off after about 1 minute.
It was a little different than "opera" lighting,........ My Wifes truck has that feature and the lights slowly DIM out. The berlinetta lights were timed and shut off completely.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
