Help: High amp FP draw w/starter (diagrams inside)
Old Jun 30, 2008 | 12:13 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I've been trying to diagnose a problem with the 3A Crank fuse blowing during starting, leading to a dead fuel pump and no fuel (when starting). I pulled the fuse, and when starting I saw that there was >15 amp current draw across the 3A Crank fuse contacts. So it looks like the starter is trying to pull some massive ground current through the wire to the relay ground. What could be causing this?
Car is an '86 T/A L69 (vin G). See the service manual diagrams that I've included in the post.
Attached Thumbnails Help: High amp FP draw w/starter (diagrams inside)-1986pontiacvingfuel.jpg   Help: High amp FP draw w/starter (diagrams inside)-1986pontiacvingstarter.jpg
Old Jul 2, 2008 | 09:37 PM
super_kev's Avatar
Car: '85 TA
Re: Help: High amp FP draw w/starter (diagrams inside)
Update: I pulled the wiring to the starter and checked to make sure that the purple wire was going to "S", and the other three (battery, 2 reds) going to the main big terminal. No shorts or bare ends there, but I still pop the fuse when cranking. Could it be the solenoid on the starter going bad?
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
