Heater Blower Motor problem
Old Jul 7, 2008 | 03:52 PM
Jim_e_d's Avatar
Hey everyone. I have a 87 T/A and I've had problems with the Heater/AC Blower staying on after the ignition is off. I've replaced the switch, and checked the coils in the airbox under the hood. I'm not finding any messed up wiring. It shuts off after pulling the fuse in the fuse box.
When the switch is in the HIGH position, the blower stays on for about 15 seconds, then shuts off, but shuts off immediately on the lower fan speed settings. I'm thinking that this is part of the problem I have with a power drain on the car, causing the battery to die.
Now that I've relayed everything, Can anyone help me out?
Jim
Old Jul 7, 2008 | 04:50 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Heater Blower Motor problem
On the High setting, the power is sent to the blower through a relay. It sounds like the relay is sticking.
You can try opening the relay and cleaning the contacts with sandpaper, they'll be likely burred and burned.
The blower relay is located under the hood, passenger side. Detailed location in the picture in this thread: https://www.thirdgen.org/forums/cool...er-heater.html
Hope this helps.
Lou
Old Jul 7, 2008 | 06:25 PM
Jim_e_d's Avatar
Hey Lou, thanks for the info. I checked the relay, and even replaced it and the same problem. The blower motor stays of for about 15 seconds after turning off the key. I pulled the fuse to see if it was isolated on the blower motor circuit...We'll see what happens I guess.
Old Jul 7, 2008 | 07:17 PM
BigBadLou's Avatar
Engine: TPI
I would put a test light (or voltmeter) on the relay to see what exactly is going on there. Specifically the orange wire and then the purple wire. I'd be curious to know myself.
http://www.austinthirdgen.org/mkport...C60_manual.jpg
Do you have an alarm? Is it possible that it is hooked into the blower system?
Lou
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
