1987 Firebird Formula 350 fuse for fuel pump
Old Jul 9, 2008 | 08:21 AM
rockrat01's Avatar
I need to replace the fuse and cannot find it. Can anyone let me know where it is and how to get to it? Thanks!
Old Jul 9, 2008 | 08:29 AM
Iroc_youroll's Avatar
Car: 88 iroc-z, 59 thunderbird 390/c6
Engine: 305 tbi
Transmission: b4c 700-R4
Axle/Gears: 2.73 open
Re: 1987 Firebird Formula 350 fuse for fuel pump
I actually just changed my oil pressure switch and ball sender lately, and somehow through the process my fuel pump quit working.
I couldn't get my car to start and couldn't even keep it running by manually energizing the pump.
Then i found out about this fuse you speak of...
It is located right next to the battery probably mounted on the fender. It looks like a clip going into a ground but its really the fuel pump fuse.
I'm sure it could be wired inline also, its easy to spot.
20 amp fuse
Old Jul 9, 2008 | 08:38 AM
Engine: 305 tbi
Also check your under-drivers-dash fuse panel for appropriate fuses and conductivity.
The fuse that also should be checked is on the top row, second from the left.
That particular fuse is a 10 amp.
Old Jul 9, 2008 | 08:56 AM
rockrat01's Avatar
20 amp fuse
Thanks for the fast response. I really appreciate the help!
Thanks for the quick response, I really appreciate the help!
Old Jul 9, 2008 | 09:11 AM
Engine: 305 tbi
I know that yesterday i was ripping my hair out trying to find out what i could of done to the fuel pump when i wasnt even working on anything fuel related and i got a fast response too.
This is a good forum!
Old Jul 9, 2008 | 10:42 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Good info.
Also, on some models, the fuse is on the passenger side fender regardless of the battery location (which is usually on driver side for Firebirds, if I'm not mistaken). That can confuse one when searching for the fuse.
Hope this helps.
Lou
RazorN8
Jan 7, 2022 11:44 AM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
