MSD 6AL, Will It Make Ay Difference?
Old Jul 14, 2008 | 09:06 PM
FastPhoenix84's Avatar
Car: 1984 Trans Am
Engine: 305CID - Bored .40"
Transmission: TH700R4
Im am in the process of rebuilding my 305, The engine has been bored 0.040" over, Bigger Cam .472 Intake and .496 Exhaust, 1.6 Rockers, Performer Intake, and Aluminum Heads w/58cc chambers. Not Sure what Carb to use yet. Anyway, As far as ignition goes I have replaced the HEI Coil with an MSD Coil. I have Purchased an MSD 6AL Box, and an MSD Ignition Module that replaces a 4 Pin module and I have a 7 Pin Module I was wondering if this 4 Pin Ignition Module will work or not. And will the 6AL be worth using or should i just not even bother and just use the stock ignition controls? The Distributor is mechanical advance. Thanks for any Info ........
Old Jul 14, 2008 | 09:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: MSD 6AL, Will It Make Ay Difference?
If you have a 7 pin module, then you don't have mechanical advance. A mechanical advance distributor woule have a 4 pin module.
The 6AL won't make any difference over a properly working stock ignition.
Old Jul 14, 2008 | 09:57 PM
Car: 1984 Trans Am
Well I know for sure i dont have Vaccum Advance. But There is a 7 pin module in the distributor. 2 pins on one side with one connector and 5 on the other side with 2 connectors.
Old Jul 14, 2008 | 10:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right. 7 pin module=no mechanical advance.
Old Jul 14, 2008 | 11:01 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Old Jul 15, 2008 | 02:38 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
That is what I have been told too. Save the money. My stocker works fine.
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
tmellott89
Aug 16, 2015 02:58 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
