Battery/Alternator charging issue
Old Jul 24, 2008 | 07:38 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I recently got an 86 IROC with a crate 350 in it. It sat around awhile (not sure how long exactly), and it's been driven very infrequently until it came into my hands. I drove the vehicle for about a week and all was okay, but now it seems as if the battery is not getting charged. The lights start to go dim while I'm driving, using the brakes, shifting, etc and so I attributed these to the alternator, which I then replaced. The car still does this even after I replaced the alternator and checked the wires from the alternator to the battery. To describe what happens more, the battery seems to get weaker the longer I drive, and if I shut the car off and then go to restart it after about 5-10 minutes of driving, it sounds as if the battery is completely worn out. If I come back half and hour later and try it, it will start right up, but the light issues persist. Any ideas?
PS. I had the battery tested at autozone and they think it's okay, although I think it is undersized for the engine.
Old Jul 24, 2008 | 11:42 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: Battery/Alternator charging issue
Try getting a larger battery, more cca won't hurt.
Although I have a 350 swap in my 86 Iroc and I am using the original size battery (its been replaced)
And what do you mean by "it sounds like the battery is completely worn out"?
Check your grounds and battery terminals, Clean them all off.
Old Jul 24, 2008 | 12:32 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Check the voltage at the battery while the car is running with a multimeter.
If the alternator is not charging, check the voltage and both pins on the plug on the side of the alternator. With the key on, both should have 12 volts.
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Slush92RS
Sep 2, 2015 08:56 PM
