Putting water temp gauge on trans?
Old Jul 27, 2008 | 01:20 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
Can it be done?
Old Jul 27, 2008 | 02:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Putting water temp gauge on trans?
Sure, the only thing that makes it a water temp gauge instead of a transmission temp gauge is the labelling on the face.
Old Jul 27, 2008 | 02:42 PM
88bird?'s Avatar
Engine: built 350
Bitchin, so my sunpro temp gauge will bolt right up?
Old Jul 27, 2008 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll need to figure out a way to get the sender into the fluid, but once you do it'll work fine.
Old Jul 27, 2008 | 03:43 PM
88bird?'s Avatar
Engine: built 350
There isnt just a place it will screw in? Any ideas how do do this?
Old Jul 28, 2008 | 07:28 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
drill and tap a hole in the pan
Old Jul 28, 2008 | 09:34 PM
88bird?'s Avatar
Engine: built 350
thats what i was thinking, except i was going to drill a whole for the sensor and weld a bolt above the hole so i can screw in the cap.
BRoss99
Aug 10, 2025 05:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
Leggman1
Aug 6, 2015 04:15 AM
