quick stereo and fuse box question
Old Aug 2, 2008 | 11:32 AM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
I started up my camaro yesterday, but noticed my radio wasnt coming on (its a sony xplod head unit) i checked all fuses and everything seemed to be in good working order, but i was wondering where else the problem could be...are there any "in-line" fuses in the wires between the fuse box and stereo i may need to check? as stated above, i checked all fuses in the fuse box, but i was still curious as to which particular fuse goes to the radio? any help is greatly appreciated.
Old Aug 2, 2008 | 12:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: quick stereo and fuse box question
Aftermarket head units normally have 2 inline fuses. One in the line for switched 12V (ignition or ACC), normally a red wire, which gives power to the radio when the key is on. The second is constant 12V for memory power and keeps your radio stations and clock when the car is off, normally a yellow wire. Of course you'll need to pull the head unit out to see these. Hope that's all it is.
Old Aug 2, 2008 | 11:05 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
yea i figured it out...there was a fuse blown in the back of the head unit...but thanks for the help anyways man...
BRoss99
Aug 10, 2025 05:08 PM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
