green relay in swingout console across from fuse panel???
Old Aug 3, 2008 | 09:43 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
anybody knows what that relay is for?? a few days ago i started hearing a constant, annoying buzzing sound coming from under the dash(fuse box area), anyway i traced it to a bad(green) relay located in that flat black swing out console across from the fuse panel. The car is an '86 sport coupe(4bbl carbed).
Old Aug 4, 2008 | 12:05 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: green relay in swingout console across from fuse panel???
Disconnect it and see what quits working.
Old Aug 4, 2008 | 12:11 AM
nothing stopped working as far as I could tell....the car is not stock by the way, it has a built carbed 355ci and i'm not using an ecm. Does your car have that relay ringo234?
Old Aug 4, 2008 | 12:16 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I not sure, do you have a picture?
Old Aug 4, 2008 | 12:25 AM
no pic but its mounted on the same pad that has the turn signal and hazard light flasher unit.
Old Aug 4, 2008 | 12:53 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
my turn signal and hazard light flasher unit are just hanging from wires under the center of the dash I think thery're located on the back of the fuse panel on yours. So I think our cars are wired slightly different. So without a Picture I'm not sure what you're talking about.
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
