moving battery back to the front
Old Aug 7, 2008 | 01:10 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok a couple years ago i moved the battery to the hatch. now i want to move it back to the front. my question is where do i bolt the neg. wire to on the block?
Old Aug 7, 2008 | 03:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: moving battery back to the front
To the alternator bracket, IIRC.
Old Aug 7, 2008 | 03:26 PM
ok cool thanks
Old Aug 11, 2008 | 04:00 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
yes, there should be a threaded hole under where the long pivot mount bolt goes, this is for all the pre- serpentine belt cars, the serp. cars have it to the block
Old Aug 11, 2008 | 06:59 PM
can i mount it to the brace for the smog pump? or should i put it on the block?
Old Aug 11, 2008 | 07:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can put it just about anywhere you like.
Old Aug 11, 2008 | 08:47 PM
ok thanks
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
AkDrifted
Aug 17, 2015 07:45 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
