speed density swap. Help!
Old Aug 16, 2008 | 08:06 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
i just finished doing s speed density swap from a 92 camaro into my 88 trans am and well as a manual trans swap. when i started it it idled at 2000 rpm and promply died. i restarts but does the same thing over and over. also i get a code 43 for the knock sensor. could this be a problem with the knock sensor, the computer i bought at a junkyard, or my custom chip? could it be anything else im overlooking? thank you!
Old Aug 16, 2008 | 10:13 PM
ParkerTPIz's Avatar
Re: speed density swap. Help!
it wouldnt be the computer, usually, especially if u have a custom prom. is the knock sensor new? if not, try replacing it.
Old Aug 17, 2008 | 09:13 AM
72vega's Avatar
some new findings... when i jump A and B to pull codes my IAC starts making noise like its freakin out. also arent my fans supposed to kick on when jump them?
85 Jimmy
Sep 30, 2015 07:56 AM
el_muerte
Sep 16, 2015 12:01 AM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
