IROCK z28 battery issue
Old Aug 17, 2008 | 09:40 AM
nabisco's Avatar
brother has a irock and if he leaves it for a while {day} the battery will be dead, now it is a new battery and the alternator checked good i was going to look at where the stereo was at maybe a crossed wire but is there anything else i should look at.
thanks
Old Aug 17, 2008 | 12:59 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: IROCK z28 battery issue
You have what is known as a parasitic drain. You will need a multimeter to find it.Make sure all lights and doors are closed.
Disconnect the Negative (-) battery cable. Set your meter to milliamps, and put one lead on the Negative (-) post of the battery, and place the other lead on the Negative (-) battery cable. If it doesn't read 0000 then you have a drain. Have a friend start pulling fuses until the meter reads 0000 When you find the right fuse you can start tracing down whats on that circuit.
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 9, 2015 05:27 PM
