Help with what to do with sensor wires I don't need
Old Aug 17, 2008 | 02:00 PM
crazypurgatory's Avatar
I'm setting up my 88 Firebird up for the 1/4 mile and I have a whole bunch of sensor wires I need to get rid of.
I did not want to cut the pigtails off them but some of them I can't hide in the wire loom.
What is the easiest and cheapest way to seal the ends of the wires so I don't have to worry about them?
Thanks,
Old Aug 17, 2008 | 04:30 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Help with what to do with sensor wires I don't need
You cut the insulation with a knife, and then you apply wirecutters into the cut but pushing the insulation 1/4" back before you snip through the conductor. That way the insulation will extend back out over the end of the conductor, protecting it from any shorts. No need for tape or heatshrink.
Old Aug 18, 2008 | 01:48 PM
That's a great idea.
I never thought of that.
The only thing is that I could get some moisture on the wire and thats what I don't want.
If I do that the only thing I can think of doing is bending over the 1/4 of the insulation and using some heat shrink tube if it will fit in the tube.
They make heat shrink caps but none in any automotive sizes just big 1inch.
Heat shrink caps would be easy and kinda cheap but o well.
Thanks,
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
