how does something affect the readings on my digital dash?
Old Aug 17, 2008 | 05:01 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im going to ask this question until i get an answer. my research has not come up with much results
i have a 1986 trans am v8 auto tpi
i have searched other posts no one ever posts their solution
how does using power windows, headlights, brake pedal, turn signal, gear selector switch ----------affect my temp gauge the most and the rest of my digital gauges are only affected alittle. like oil reads 45 psi then use one of those accessories and would reads 43-46 give or take
but my temp gauge goes up in degrees with brake pedal and all those other items are being used
and it all adds up brake pedal adds 20degrees on the gauge, headlights another 20
stop using these items and guage goes to normal
voltage gauge is only effected by plus or minus .3volts when using an accessory
i have already re-wired the 12v source and ground wire, its feeding off the radio 12v wire and ground is all the way bolted to radiator frame/chassis just off of the negative wire from the battery
still have the same problem
there are also other 12v/ground wires to power the engine light and brake bulb and seat belt bulb
could those wires affect the gauge read outs somehow?
voltage regulator and alternator i have not tested but the car charges, turns on with no problems and volt gauge stays between 11-13volts depending if car is on or not or using some accessory
so what could it be that affects the reading on my digital gauges?
Old Aug 17, 2008 | 06:58 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: how does something affect the readings on my digital dash?
Just a thought, but since all your gauges are electronic and get their power from the electrical system. When using electric devices the voltage may flutuate slightly changing the reference voltage for all of you gauges.
Old Aug 17, 2008 | 07:38 PM
Bobby_80s's Avatar
Axle/Gears: no idea
sob!!!!! i got it
the chassis ground wire directly from the battery!!!!!
the tip where it connects to the bolt and frame/chassis was all brittle and slightly corroded
i replaced the wire and bingo!!!!!!! whaahahaaha
thanks for replying ringo
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
