1992 Camaro RS gauges
Old Aug 17, 2008 | 06:56 PM
Naive Beast's Avatar
I have a 1992 Camaro RS, with all orginal interior, including dash and all. I'm new to cars and modifying cars, hell, I'm new to owning and driving a car. But i want to put in aftermarket gauges, just something that looks neat, maybe digital.
Is this possible? If so, where would I get the gauges? Would I be able to remove the original gauges, or would I have to build over the originals?
Thanks in advance for all the help.
Old Aug 17, 2008 | 11:04 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 1992 Camaro RS gauges
Nordskog makes a digital replacement for 3rd gen Camaros, installation requires some wire splicing and replacing some senders.
http://www.nordskogperformance.net/p...003-dp4005.htm
If you really want to spend the money, Dakota Digital will take your analog gauge cluster and refit it with digital gauges - takes about 90 days. Installation for these also requires wire splicing and replacement of senders.
http://www.dakotadigital.com/index.c...rod/prd214.htm
They turn out like this, a picture I took on the rollers of a dyno...
I have about 70K miles on that cluster
Old Aug 17, 2008 | 11:33 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
im sorry thats just friggn cool. too bad its roughly $500
Old Aug 18, 2008 | 12:57 AM
That does look pretty sweet. So getting new gauges in my car is not a 'drive down to auto zone and pick a new cluster' type of thing?
Old Aug 21, 2008 | 04:05 PM
*bump!*
Old Aug 24, 2008 | 11:18 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
for digital..no but if u just wanted standard aftermarket guages you could get some kind of sheet metal to make a custom gauge set but just so u know its not a plug n play mod, there will be wiring to be done. you should probably invest in a shop manual...factory one would be ideal but if that is out of your price range a haynes still helps out a little, just remember its not god it can be wrong.
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
