Almost caught fire! please help
Old Aug 25, 2008 | 07:26 PM
HeavyMetal350's Avatar
Car: '91 z28
Axle/Gears: 3:73 gears
ok ... so when i bought my camaro a year ago, they guy told me that he keeps the cig lighter out of the dash because it always blows a fuse. So I tested it and for about a year now it has worked fine with n/p. Well then just recently I started to blow my ACC fuse. I didnt remember to think that it might be the cig lighter and I just kept changing the fuse while I was trying to decode the problem. Then on the way to work one day I noticed smoke rolling out from under my dash and mostly comming from behind the lighter! I freaked out and pulled out the lighter. It wasnt red but it was hot and the smoke stopped. Can anyone maybe shed some light on why this happend?? I havent used the lighter ... ever lol. but since i have kept it out and i havent blown a fuse or caught fire lol in a few weeks.... any help would be very appreciated!
Old Aug 25, 2008 | 11:23 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Almost caught fire! please help
I suspect that you have the hot wire grounding on something. If you pull the cig lighter socket out, i suspect it will be really obvious.
Old Aug 26, 2008 | 01:46 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I had a short in my cig lighter and it was caused by the edge of the bi-metal contact spring clip shorting to the sorrounding metal cylinder. I just used a small screwdriver to bend it in a little. The bi-metal spring is the thing that holds in the lighter until it gets hot enough to cause the bi-metal to bend outwards and release the lighter.
Sometimes the short can be caused by a small metal object finding its way into the lighter.
Use a small flashlight and inspect it closely, and/or pull it out like drknow says.
Old Aug 28, 2008 | 01:48 PM
Car: '91 z28
Thanks guys.... it was a problem with a small piece of metal that somehow found its way inside the socket. lol that saved me alot of headache.
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
fasteddi
Sep 10, 2015 09:32 AM
