Brights stuck off ~ Floor dimmer?
Old Aug 28, 2008 | 12:56 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
I read the how-to but I still dont understand. It also seems like its for the cars that have brights stuck on. How do I install it?
Old Aug 28, 2008 | 05:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LIGHT SUBJECT
It sounds like your dimmer stalk
is not functioning.
Do you have a tilt steering wheel?
If so - hardware can come loose
which causes an incomplete tilt
range disabling the dimmer.
Happy Racing!
-If people drove any slower
they’d be going backwards-
Old Aug 28, 2008 | 08:43 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: LIGHT SUBJECT
is not functioning.
Sorry about that, I completely forgot to mention that I know why they wont work, and yes that is my problem. But what I wanted to do is the floor dimmer mod, but the write up doesnt exactly apply to me (or so I think). So I was wondering if someone could tell me how to do it on my car.
Old Aug 30, 2008 | 11:09 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: Brights stuck off ~ Floor dimmer?
Ok Im looking in the Haynes manual and from what I understand there is a switch with an input (yellow), and with an output for low (tan) and hi (light green) beams. If Im correct; where are the wires actually located or where is the best place to tap into them? Or do I have to go into the steering column to get to the tan and lt green wires?
Old Aug 31, 2008 | 03:46 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
If you remove your knee-pad from below the column and look up on the top of your steering column, on the right side you will see a connector that is long and has many wires.... You will find the wires you are looking for....
Old Aug 31, 2008 | 05:37 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Thank you!
F-body-fan
Jan 12, 2023 01:49 PM
tmellott89
Oct 14, 2015 02:06 PM
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ctoledo0834
Sep 18, 2015 04:16 PM
