Gauge Cluster Messing Up - Sensors or Cluster?
Old Aug 28, 2008 | 01:02 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Like the title says... Speedo, batt and fuel all work fine. Temp is inaccurate. Oil pressure pegs and flickers. Right side lights dont work. Aftermarket Tach is installed so of course that doesnt work.
I had an issue like this before, and all I did was roll up elec tape and stick it behind the connectors so they would push harder against the contacts, and all came out fine. Should I do this again or assume its the sensors (whatever theyre called)?
Old Aug 28, 2008 | 11:17 AM
chattersonm's Avatar
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
Re: Gauge Cluster Messing Up - Sensors or Cluster?
mine has the same problem, lol.
i have no idea whats going on
Old Aug 29, 2008 | 10:49 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Well Im going to try and do what I did before. Got to get other things fixed first though. Ill post if it works. Dont know if it will apply to you because our clusters are quite different. Still though, it may connect the same.
Old Sep 1, 2008 | 09:16 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
righto lol
GTAman
Jul 3, 2024 07:29 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
