replaced headlight motor, still not working
Old Aug 29, 2008 | 04:11 PM
nidan14's Avatar
my left motor was out, so I found a replacement online and installed it today only to find out that the headlight still won't go up. I tested the motor on the right side to make sure the motor worked, and it did. Since the motor does work, I'm guesing it's something electrical. I don't know much about wiring, but does anyone know what might be the problem and how I can fix it? Thanks
I forgot to mention it's a 91 firebird
Old Aug 29, 2008 | 05:11 PM
irok2fast4u's Avatar
Re: replaced headlight motor, still not working
check power with a test light, if nothing trace ground back or do a resistence test the wire. If not just tap into the other sides wires and and run themto the other side.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Leggman1
Aug 6, 2015 04:15 AM
