Wiper WTF?
Old Sep 4, 2008 | 02:51 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Wiper WTF?
Hey guys, i was coming home today and it was raining so i had the wipers on. Well they are working fine but what im wondering is i noticed the driver side wiper was actually coming off the windshield and over the windshield weather striping and i was wondering if anyone elses did that. thanks -Matt
Old Mar 28, 2011 | 06:29 PM
str8jz42's Avatar
Car: '86 Trans Am
Engine: 305 4bbl
Re: Wiper WTF?
This is usually caused by 1 of 2 things. The first one being the wiper arm may have slipped on the splines or the splines are stripped. Check to see if the wiper is all the way down when the wipers are turned off. If the drivers side one is parked higher than the passenger side one, remove the wiper arm and install in the correct position. Be sure to inspect the splines on the shaft and the arm for wear.
The second cause is the wiper blade being too long. I have the same problem because I installed aftermarket double wiper blades and the driver side one is longer than stock so it wipes off of the glass an inch on the end of the blade.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
