Why is my dome light always on?
Old Sep 4, 2008 | 08:39 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
It just started happening out of the blue. I noticed it while driving. I made sure all the doors were shut and that my light switch was off. What could be causing this?
Old Sep 4, 2008 | 09:57 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Why is my dome light always on?
Check your door pin switches. One may be grounding out. You may get lucky and be able to remove the switch by just unscrewing it. If one of the connectors has come free and is grounding out you'll need to pull the kick panel to reinstall it.
Lon
Old Sep 5, 2008 | 11:54 PM
BCdawg57's Avatar
Yep. MY PCM fell down and made contact with one of the door switches, grounding it out.
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
