Bypassing the keydecoder???
Old Sep 4, 2008 | 11:54 PM
shdtree3's Avatar
Car: 1990 Camaro RS
Engine: 3.1 L
I have a 1990 Camaro RS with the 3.1L, the starting circuit went out and I have traced it back to the starter relay I think. According to the wire diagram the starter relay is powered by the key decoder at key on. Is there a way to bypass this and/or a way to check if it is working properly. I tried to manually close the relay and got the engine to turn over with the starter but it will not start. Any help would be helpful. Thanks.
Tim
Old Sep 4, 2008 | 11:57 PM
Stephen's Avatar
Car: 87 GTA
Re: Bypassing the keydecoder???
Measure your key chip to find out the resistance value. 9 possible, IIRC. Pull the 2 wires down (that read the key) and solder in the needed resistor. No more chipped key needed.
Old Sep 5, 2008 | 12:00 AM
shdtree3's Avatar
Car: 1990 Camaro RS
Engine: 3.1 L
thanks for the reply but will that help the starter relay from working or not?
Old Sep 5, 2008 | 12:03 AM
Stephen's Avatar
Car: 87 GTA
I believe the chip only kills the ignition system, not the starter action.
In other words, no...The starter will spin all day, but the ignition will never fire.
Old Sep 5, 2008 | 12:06 AM
shdtree3's Avatar
Car: 1990 Camaro RS
Engine: 3.1 L
ok that makes sense. will try and see what happens.
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
