Wiring the Reverse light on LT1 swap
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
I would like to wire up my reverse light on my 86 camaro. The reverse light that needs spliced is coming out of my LT1 wiring harness and is a bright green color. I was looking through my wiring on the old harness of the camaro, and where the old connectors are that went into the computer under my dash the same colored wire is going into one of the connectors. Everything else on my new harness and the old harness have been all the same color wires, so should I cut this bright green wire that is going into the old connector for the computer and splice that into the new LT1 harness reverse light wire? Or should I be looking for another spot on the car that this should wire to. Thanks for the help.
