85 Trans Am Tach Issue
Old Sep 15, 2008 | 11:39 AM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
1985 Trans Am Cluster Tach Problem
Hi:
I have an issue my my Tachometer that stopped working. All the other gauges work.
Without removing the entire cluster, I purchased another cluster from another 85 Trans Am with same 305H engine. Removed that Tachomter Gauge and replaced into my cluster on my 85 Trans Am. The match is perfect and it does work, but is reading is 5K higher than what is should be, around 7500.
I figured to give it a shot before removing the cluster and send it out for repair.
Any help would be greatly Appreciated
Rob
Old Sep 17, 2008 | 08:19 PM
gmpptech's Avatar
Re: 1985 Trans Am Cluster Tach Problem
Does your car have MSD ignition or similar equipment? If it does it has multiple sparks per fire, especially at lower rpm's. You will need to get your signal from the box itself to get the tach to read right.
Old Sep 17, 2008 | 08:36 PM
Axle/Gears: 3.08
Re: 85 Trans Am Tach Issue
Engine and Ignition System is all GM.
eightsixseven
Dec 16, 2024 01:50 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
