plenty of power except on launch? help please
Old Sep 18, 2008 | 07:38 PM
85ZzZ4's Avatar
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
went to the strip this week and was running strong for most of the night.. right at the end my car started falling on it's face right off the line, almost stalling even, i would let out and get back in it and it would rocket through the rest of the track... could this be an ignition issue? my set up is a zz4 crate motor with fast burn aluminum heads, msd 6a ignition, new plugs, not so new wires, and not sure how old distributor....
a guy at the track said worn out distributers will start acting up when they get hot and i made sever passes right in a row... is there any truth to this?
Old Sep 19, 2008 | 01:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: plenty of power except on launch? help please
I've seen ignition modules act up when hot, but I wouldn't imagine the distributor itself would be affected by heat. It sort of sounds like a fuel issue though, are you running a carb? I'm wondering if it could be related to the accelerator pump, either not working, or flooding the engine with too much fuel.
Old Sep 19, 2008 | 11:54 AM
85ZzZ4's Avatar
Transmission: th350
i am running a carb with a holley electric pump... so i don't think its fuel.. but i'm new to all this... i'll have the autozone by my house check the ignition module... thanks for the tip...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
beast94
Aug 20, 2015 06:44 AM
