Headlight Problem!
Old Sep 19, 2008 | 02:33 PM
noecker55's Avatar
Car: 1991 Firebird T-Top
Engine: 305 tbi
Transmission: t-5 manual
Axle/Gears: 3.08 Open
Headlight Problem!
Hey everyone, I recently put in a set of projector headlight conversions for my '91 firebird and I've been having all sorts of problems. First off, here is the kit http://www.driftnamiperformance.com/...t-lhp4x6jm.htm.
I put in new wiring harnesses for the H4 bulbs and that is the only modification to any of the wiring system I have done. The first problem is that my indicator for my brights is on at any time the headlights are on, it switches between hi/low beam but the light stays on. Next and probably the more serious problem is that the light output is junk! The low beams work fine but the hi-beams are very dim, and I've noticed that the engine seems to be working harder when the lights are on. The bulbs that came with the casing are 100/90W, could this just be too much draw from the car? As I have said, I have done nothing but splice in the new wiring harness for the H4 and put the assembly in the car. Any help would be greatly appreciated!
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
