im ticked off
Old Sep 27, 2008 | 10:37 AM
zach1991's Avatar
im ticked off
somebody broke in to my car last night and riped my ignition out. now it wont turn so i cant start the car how do i replace that and where do i find one
Old Sep 27, 2008 | 10:41 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: im ticked off
do u have the original key? if so take the key to napa/autozone so they can check it to find a replacement ignition that matches the key resistance.
Old Sep 27, 2008 | 11:18 AM
zach1991's Avatar
Re: im ticked off
yes i do didnt think about that but how do i get the old one out of it
Old Sep 27, 2008 | 11:32 AM
Stephen's Avatar
Car: 87 GTA
Re: im ticked off
The ignition switch itself doesn't care about the value of the VATS key.
There is a separate box in the dash, that is wired to the ignition switch, to check the resistor value.
Chances are, you can go get a new cylinder from a junkyard, wire itup & your car will be just fine.
Old Sep 27, 2008 | 12:20 PM
zach1991's Avatar
Re: im ticked off
how do i get the key switch out of it
Old Sep 30, 2008 | 08:50 PM
badtimmy1's Avatar
Re: im ticked off
You probably need to replace the rack and sector that links the ignition switch to the ignition cylinder. If you're not familiar with column repair work, you'll have to have it done at a good dealer or theft repair center. The procedures to replace these parts is quite extensive. Requires a steering wheel puller, lock plate remover/installer tool, and a tilt housing pin puller, and a lot of patience, especially during re-installation.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
