I broke something on my dome light circuit
Old Sep 28, 2008 | 01:56 PM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
i installed a new radio and while i was working on it one of the hot wires hit a screw and sparked and it popped the radio fuse, now i have no power locks, dome light, courtesy light, or trunk popper. i checked all of the fuses including the power acc fuse and it shows fine on continuity test, i have also pulled the harness off of my cig lighter and checked both door push switches for good grounds, im stumped.
Old Sep 28, 2008 | 02:30 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: I broke something on my dome light circuit
check the fusable links
Old Sep 28, 2008 | 03:05 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Whats your car? If a camaro, theres another fuse/relay box on the right side of the steering column under the dash. There is another fuse for the radio in there. The door tone module is also there with a relay or 2. Firebirds might be the same but not forsure.
Old Sep 28, 2008 | 03:06 PM
thekevin's Avatar
Car: 1985 Z28
is there something that shows where those fusable links are.
sorry for the description, its a 85 z28, tpi 305, automatic
Old Sep 28, 2008 | 03:14 PM
jermdm's Avatar
Car: 1989 Iroc-z
In my chiltons manual, it shows the fusible links are down at the positive terminal of the starter and the battery.
Old Sep 28, 2008 | 04:17 PM
thekevin's Avatar
Car: 1985 Z28
the one by the batter had some water in it at some point in time so i changed it, i didnt see one anywhere around the starter.
Old Sep 30, 2008 | 09:55 AM
thekevin's Avatar
Car: 1985 Z28
I was thinking of running a new hot wire with a fusable link from the battery to the fuse block for these, which wire is it going into the fuse block that handles these.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
Omega
Aug 10, 2015 12:46 PM
