headlight problem
Car: 1983 firebird
Engine: 350 lt-1 crate motor
Transmission: borg warner t-5
Axle/Gears: stock 3.27 posi rear disk
headlight problem
i changed the engine in my car now the headlights and parkings lights wont work i've repleced the switch and checked all the fuses still nothing, any ideas?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BRIGHT IDEA
It sounds like you snagged a wire or two when you put in a fresh engine.
Apparently you didn’t see anything obvious. Therefore start tracing.
The switch is a good starting point.
See if you get power to one side, if yes trace towards the lamps,
if no trace towards the power.
Happy Racing!
-If people drove any slower
they’d be going backwards-
Ghettobird52
Jul 5, 2024 11:18 PM
